It is currently Mon Jul 21, 2025 7:36 pm
PostPosted: Mon Feb 26, 2007 1:53 pm
bigger is better...
unless you have to pay by the square millimeter!
PostPosted: Mon Feb 26, 2007 3:05 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
I have the six-inch set and they are awesome for neck shaping. The ten-inch
may be a bit big to work the transitions from neck to peg head and neck to
heel, especially if your neck is attached to a body.   That said I usually use
the last inch or two of the file in these areas and the short file is plenty long
enough.
Louis
- Louis Freilicher
PostPosted: Tue Feb 27, 2007 7:53 am
Using the ten inch set and theyre great for working necks. Dont however use them for working tuner slots on a classical....easy to end up with off square slots. How did I find this out...dont ask
